I have acquired a 95 Xplorer 400 4x4 Model W959140 from the father in law. He broke off the front right cv shaft about 8 years ago and it has been sitting since then, It was running perfect when he parked it. So anyway i have a few questions about what fluids i need to flush before starting it up. It's a 2 stroke so i know there is no engine oil.
Questions:
1. Does the front hubs have fluid in them or do i grease them and install it. I have seen people online filling them with fluid and such, but i have also seen people greasing the bearings and that's it
2. I believe that this is the correct way to drain and fill transmission fluid Am i correct?
3. I pretty much know how to flush the rad and i'm going to put new hoses on
4. @thepepper said
"The counter balancer can be very problematic on these machines. You have the oil pump driven off one end and the water pump on the other end. It is quite common for the seals to wear out and coolant seep into the counter balancer oil and contaminate it. If not caught soon enough, the shaft becomes pitted and no seal will keep the coolant in. I had to send mine away to a company that machined it down and pressed on a stainless steel sleeve to bring it back to spec. There is a weep hole under the machine that is supposed to let the coolant out but it quickly gets plugged with mud. I added a drilled out zerk fitting to the weep hole and a short piece of clear tubing to I can keep an eye on mine "
please explain more, i'm new to ATV repair
5. Replaced spark plug
6. Drained and flushed both the fuel tank and oil tank. Both are nice and clean.
7. Replaced inline fuel and inline oil filters and air filter.
8. Any other fluids i need to tend to that you suggest? Please advise
THANKS!!!!!
Questions:
THANKS!!!!!
