I need some help,
I have a 1996 425 magnum 4x4 and my battery is not charging what do I check and do. please help
T.S.
425's should have an "LR" module that works as a voltage regulator. I've seen more of these go bad before a stator will. Not a good way to test them other than smell for burn. Or put a new one in and check voltage at the battery to check for a difference. Let me know how it turns out.
The module is located behind the front bumper on the left side. Check all your wires for good connection. There is a problem with this Voltage Regulator going bad but I guess I just lucked up and found a bad wire that was pinched.
