1 - 2 of 2 Posts
The front sprocket on my Magnum is tore up. Has almost no teeth to it and I need to change it. I went to the Polaris store and got the right sprocket and now I need help as to how I change the front sprocket. Thanks in advance for any help.
loosen chain, remove cover if it has one, remove bolt that holds sprocket on and change sprocket, you should replace both sprockets and chain, replacing one will cause the new one to wear out quickly.
1 - 2 of 2 Posts
