Just wondering what is involved in replacing a non-working recoil assembly. Will be getting a replacement assembly. Is there any fluid in this assembly, as I see there are a couple of plugs. The gasket is no longer available..... Is permatex copper rtv OK to use instead? Hoping this is simply unbolt the old one and olt on the new (used) one. Thanks.
Sent from my SM-N960U using Tapatalk
The existing recoil rope just pulls out without catchinv. The rope does go back in as it should. Will this problem be saved by just installing another recoil unit or is it something else?
