I have the rear brake caliper off a 96 Magnum 425. It has the mechanical foot brake that has a cam that closes the caliper on the brake disc. The pin that operates the caliper piston seems to be really tight on the bore. Should the spring on the pin that operates the caliper piston be capable of retracting the pin after the foot brake is operated?
