The only lights working on the dash are high beam. The lights for neutral safety, temperature and reverse are not working. The neutral safety on the transmission is not working and also the 4 wheel drive. The front 2 coils ohm out fine and so does the awd switch. I know the neutral safety switch is not working because it will start in gear.
Can someone help me with this?
It could be that the bulbs are simply burnt out on the others. I would start by checking each bulb. Have to take dash apart but its worth it. That worked on my 94.
so i am having the same problem i have a 01 500 sports man ducks unlimited forward and reverse work fine power is at the awd switch i have power at the grey and white wires under the cover have power at the hubs i have power nuetral forward nor reverse light works where is the neurtral switch please help with any other ideas for the 4x4
