I was hoping someone may the Napa part# for rear u-joints on a 96 sportsman 500. I need the joint that is on the outside(wheel side) of the rear axle. I believe the Polaris part# is 1590257.
Also curious how difficult a job is it to do? Doesn't seem like it should be to bad, but also know sometimes looks can be deceiving.
Thanks for any help provided.
AJ
thanks for info. I will see if local stores have neapco ujoints or can cross ref their part No..
Thanks for the welcome.
Neapco u-joint part numbers for rear inner and outer..
Inner--Neapco 1-1875
Outer--Neapco 1-1275
I picked them up at Proven Force(AKA Clutch and U-joint) here in MN.
Thanks for the help.:veryhappy:
