1 - 2 of 2 Posts
My 500 died about a month ago and I've tried everything I can think of to fix it and can't figure it out.
I test the CDI per the manual and got the correct ohms, I do have a spark at the spark plug, new plug and trigger coil test good per the manual.
I try to crank it over and it spins and then acts like it hits something internally, it stops spinning the engine and then will start spinning again. Usually when I let off the starter it seems like the engine actually fires.
could the timing be off?
Test the stator,take a look at flywheel key,flywheel magnets, then check camshaft.
You might have a bad key switch or on/off switch.
1 - 2 of 2 Posts
