I pulled the driven clutch out and the spring has several holes it can be locked into. 2 on one end and 3 on the other. What are these for. I'm not sure which ones mine came out of.
Welcome aboard. You should try posting your question in the section setup for your ATV or the maintenance section. You will get more responses that way.
Take care,
