Just bought a 97 sportsman and the 4 wheel drive wasn't working. After going through the electrical ohming everything out and checking volt readings I determined that the switch wasn't getting any power. I have a Clymer manual that has electrical schematics but after looking at my switch they don't match. My Clymer manual shows two wires a gray and gray white coming off AWD switch but on the actual switch I have four wire a brown, gray, gray and white, and a yellow wire. I looked all over for the yellow wire all others were landed on the board. After messing around I found that the yellow wire was spliced with the gray and white inside the tubing sleeve. I can't figure out if this is the way it should be or not. Something looks rigged with it. Does anyone know where these wires should land or have any ideas that might help. THANKS I'm clueless
