The four wheeler had not been ridden in about four months. I got it started and road it about 400 feet and both front tires brakes locked tight as a drum. I tore into it today and found the fluid in the reservoir was discolored like rust. I cleaned it out and took the reservoir off and tried to get fluid flowing through the little holes in the mount. Reassembled it and mounted on the bars. Now I am getting nothing at coming out of the connection for the hose. I am hoping someone on here can point me in the proper direction. The brake lever was VERY hard to pull before I took it for a ride, now the lever works freely but is NOT pumping any brake fluid at all. HELPPPPPPPP
