I recently put a new carb on it and it sounds normal at rev when i rev it up then it starts sound like its hitting a rev limiter and when I try riding its half power with short busty of full power I've set the adjust to 1 1/2 turns I've tried 2 turns with no luck can anybody point me in a direction to fix it
Presuming it's a Sportsman 400 4x4 and not the Sport 400L, have you tried holding in the OVERRIDE button to see if it will run normally? You may have a problem with the reverse speed limiter - holding the override button disables the limiter.
