Howdy fellers....I have found a great lookin 97 400 Sportsman for sale. Guy that owns it says the 4wd button don't work. He said it just quit. What can I look for when I go look at the bike??? How does this system work??? I'm interested in it...but don't want to buy junk...:cowboy:
I assume it's a two stroke .
Check the counter balance oil dipstick is on top of motor . Make sure it's not milky make sure it starts , check the radiator , 4x4 is an easy fix . Just run a toggle switch to it and bam it will work again . It's run off magnets .
Bikes nothing as long as it goes into gear , no milky oil and starts up and also listen for a bottom end knock .. If it knocks then walk away .
Dodge the father Ram the daughter
