1 - 2 of 2 Posts
I replaced key switch , coil, spark plug, and still no spark. I resistance tested the coil, coil mounting, stator and did a voltage out put test which all passed to the specs in the Manuel. They thing I had trouble with is the coil mounting bracket to the coil has no continuity should I remove the coil sand off the paint that is on the bracke and try again is that the problem possible or since I tested everything around the cdi box and t passes is it the cdi box. Can't find them on eBay either. Please help a brotha out. Thanks in advance .
Discussion Starter #2
Got another question there are two wires running from the front to back under m seat it's a red and a red / black wire that's two terminals like they hook up to something but I ain't find what they hook up too. One is ground and one is hot . Any ideas??
1 - 2 of 2 Posts
