Hello, My 97 Xplorer is not shifting into High or Reverse. The shifter handle does not lock into place. When I remove the linkage rods the shifter moves correctly. When I push on the linkage rod to try to shift without the shifter handle attached, it does not lock in to reverse or High. I have tried to adjust the length of the linkage rod, and had the same results. Any suggestions?
Steve
rpms have to be high enough to allow engagement, not sure what the magic number is I'm sure someone will pitch that in for you. have u messed with anything lately that could have changed your idle speed?
Thanks for the reply. I replaced the stator and it has not been working since then. It has worked once or twice. I've tried rev it up a little and put it gear that way. No success. I meant to add the info about the stator.
