i have a 98 scrambler 400 4x4 when i press the throttle i almost have to push the bike to get it to move once it is moving it has good top end speed any suggestions on where to start lookingto correct this problem
Needs new belt or the belt deflection needs to be adjusted. The belt defection should be 1 1/4 to 1 1/8 inches. It could also have internal clutch problems which would be minor if any.
also make sure your sprockets n chain are in good shape , any noises ?
