I have gone through my clutches, opened up the transmission only to find no problems but my express 2wd wont go into high. I have a lot of white smoke when engine idles.
Welcome to the board!:med:
With the shifter in neutral, remove the outer shift rod, adjust as neccessary until the ball end just fall into the shifter hole, do the same for the inner(low range) after you get the outer set.
Most likely the shift shaft is getting worn, you may have missed it, when you split the cases.
