When I put the quad into four wheel drive only three out of the four tires will spin under power the front left is limp as its out of four wheel drive. What would cause this? Any info is appreciated. Thanks for all the help before I got the motor and alignment issues taken care of.
There's two wire running down the spindles on each side. They break easily
Ok thank you. I'm waiting for the snow to melt off the quad and then I'm gonna tear into it. Is there a way to check them? Volts, ohms? Both wires have power or is one a neutral and the other hot? Is there a common area where they break?
Thanks for your help and a starting point.
Jason
I assume one + one - I could easily see the broken wire when I pulled tire off. They are siliconed into a groove in spindle.
