1 - 8 of 8 Posts
i have a mint 98 sport 400 2wd, needs a new chain, while i'm at it, im looking to upgrade my sprockets. stock is 13/34 for a 2.62 gear... want a lil more bit outta the hole. where to buy? will i need a longer chain? anyone done this? any advise would b great.
mods are: dg exhaust, stock clutch(for now) stock tire height, 32mm carb jetted, k&n filter.
Thanks!
Welcome to the board!
do you EVER give any advice OR u just say "Welcome to the board!"???
:werd:
Funny :) ...............its just one of his perks
I used to do this with my 2 stroke Suzuki.
I added horsepower to my machine by doing a lot of work to it. ie; milled head, bored out, larger piston, ported, reed mods, flywheel lightened, bored carb etc.......Where I am going with this is you may want a bit more low end but your machine may not like it, especially stock.
Clutching is an alternative or an addition to transfer the horses to the rear wheels.
Takes a bit more power to get her going, even with 1 tooth added to the rear and even with an automatic like the sportsman's, just as an example.
By removing 1 tooth on the front sprocket, you will gain a lot of bottom ( very noticeable ) and loose a bunch at top end.
You might have to play around with the right combo from front sprocket to rear. Bottom line is, You might have to buy a few to get it to your liking. And of course, you will have to get a longer chain if changing the sprockets.
Kind of hard to explain on paper as opposed to in person. But by trial and error, you will get the picture real quick....
i'm just looking at upgrading the rear sprocket to 42 tooth... that gives me a 3.23 gear ratio up from stock 2.62
question is... how much longer chain do i need? stock is 84 links
What I had to do was by a chain from a local place that sells chains. Not a dealer. Bought one longer than stock ( they cut to my specs. ) and used a chain breaker to get the length I needed. Had to buy the link pin to lock the ends together then adjusted the machine accordingly.
Discussion Starter · #7 ·
yeah, thats what i was just looking into. prob going to buy a longer chain, than cut off what i don't need.
Most likely your best bet. My Suzuki had a pretty good range of adjusting. I made sure the chain had room to move for adjusting. 2 strokes loved to stretch chains.........don't know what yours will but leave room for adjusting from loose to tight.
Oh, Welcome to the forums! :)
1 - 8 of 8 Posts
