98 Sportsman 500 oil drain plug replacement.
1 reading
2.3K views 5 replies 3 participants last post by  babylegsohurlahan
Good day,
I'm looking for a replacement oil drain plug for my sportsman, but I cant find one for a 98. Is there a different year of sportsman that would work? Or does anyone know what size bolt I should be looking for? Typically I just buy things like this on amazon, and there are several different options, I'm just not sure what would work.
Thanks!
#3 ·
Drain plug for the oil tank; right? Part number is 7051524 - it is a 12 mm bolt with an aluminum sealing washer - Honda drain is 12-1.50 - Polaris may be 12-1.25, but any common bolt with a sealing washer will work as long as it is the correct thread and no more than 1" long - about 3/4" is right - even 1/2" in length will work.
