1 - 2 of 2 Posts
Looking at getting a Rammy flail mower for at the cabin. It attaches like a plow to a center mount plate. Having a problem finding one for the Xplorer, but wasn't the frame the same as Sportsmans of the same years? Warn makes one for Sportsman 500 going all the way back to 96. Wouldn't that be the same?
Discussion Starter #2
In case someone comes searching for this info, the Sportsman mount isn't an exact fit but it's close and easy to make work. Only one U-bolt isn't usable on the right side frame because of the chain drive to the front. IDK about the shaft drive front models, it may work ok. To replace that missing U-bolt, I just drilled an extra hole thru the mount and bottom of ATV and added another bolt to that side. Everything else fit.
1 - 2 of 2 Posts
