Where can I find a replacement shift lever?
Many sites show the part number 5631054 but all are saying “not available”?
Started with troubles getting into reverse, recognized some play in the lever which may or may not be the issue...
Had to tap the lever off and can see the splines are...
2001 xplorer 250 4x4
I noticed last week the neutral light wouldn't always come on. it I turned the key off and on once or twice the light would come on and itd start fine. now the neutral light wont come on at all so I have no electric start now. I can pull start it fine. where should I start...
Hello, I have a 98 Polaris xplorer 300 4x4 two stroke and I cannot get it to idle, I have tried the air adjustment screw and the idle screw and nothing. Due to the age of this atv I cannot seem to understand if the “kill switch” on the thumb throttle is touching to make it die but I cannot...
The gear selector on my 00 400 Xployer is very sloppy and will jam when trying to use low range. Snow plow season is coming up and I’d like to use low range.
How difficult to rebuild and what parts should I replace. Any videos of the shifter rebuild?
