1 - 2 of 2 Posts
I have this old Xpress 300 which was not running when I bought it. I am considering buying a AMG battery, but would like to check to see if the stator will charge the battery before spending the $. Also any way to test the voltage regulator? Any help would be greatly appreciated.
The stator does not charge the battery - the rec/reg does that - the stator simply generates AC voltage
Check the AC voltage between the yel and yel/red wires disconnected from the rec/reg at both approx. 2500 and 5000 RPM - then check the AC voltage with the wires connected to the rec/reg and let me know what you measure.
1 - 2 of 2 Posts
