1 - 13 of 13 Posts
don't have a manual for this but took carb out to soak and clean. (constant drain from overflow even while running). New to me vehicle. When I took the plunger out of the top, As i removed the cable from the plunger everything slipped out of my grasp and I LOST a plate that locks the cable into the plunger. Would like to know the name of that part and a Number for it. Spent hours looking and no luck finding it.:str: No plate, no go, not good!
1 3130060 TOP,MIX CHAMBER 1
2 3130354 SPRING,THROTTLE 1
3 3130002 PLATE,THROTTLE 1
4 3130356 JET NEEDLE Substituted by 3130155 (5DP7-2) 1
5 3130355 WASHER 1
6 3130420 VALVE,THROTTLE,(2.0) (2.0) 1
7 3130359 CAP, PLUNGER 1
8 3130006 SPRING,PLUNGER 1
9 3130328 PLUNGER ASM, STARTER 1
10 3130012 SPRING,AIR ADJUST 1
11 3130011 SCREW,AIR 1
12 3130010 SPRING,THROTTLE ADJ. 1
13 3130324 SCREW, THROTTLE STOP 1
14 3130067 JET,PILOT,#40(10) (#40) 1
15 3130014 WASHER (10) 1
16 3130025 SCREW & WASHER(10) 4
17 3130321 BOLT,BANJO 1
18 3130239 O RING 1
19 3130109 JET,MAIN,HX.HD#130 (#130) 1
20 3130441 BOWL,FLOAT,(250) 1
21 3130021 FLOAT ASM 2
22 3130237 CAP,(10) 2
23 3130020 PACKING,FLOAT CHAMBER 1
24 3130360 VALVE, NEEDLE (2.5) 1
25 3130018 ARM,FLOAT 1
26 3130361 PIN, FLOAT 1
27 3130017 PACKING(10) 1
28 3130424 CARBURETOR (Incl. 1-30) 1
29 3130409 JET,NEEDLE(0-4),169 (0-4) 1
30 3130003 E RING(10) Substituted by 3130508 1
Go here for the Polaris Parts Browser http://parts.polarisind.com/Browse/Browse.asp
build your quad and look under the carb section for a pic you can enlarge to see easier.
Buddy
Glad I could help, Buddy.
Don't worry, as soon as you wait a week for the dealer to get you one and get it installed, the old one will fall out on the ground in the garage. Never fails.
So true, I've always said "If you want to find something, replace it and you will trip over the old one in 10 minutes."
Dealer had NONE. If ordered he'd have it by next Friday. Online, $6.83 plus $10+ shipping and still Mon or Tues. Oh well, Make one. NO sheet brass in shop or nearby town. Think....think....brass tubing? Home Despot plumbing pipe! Any way I got it cut and split a length, laid it out and cut it. It worked really well.
Next question. In the last pic that fitting seems to need to be tied into the tube coming out the bowl overflow. Is that correct? Oops! will post again for last pic.
Thanks, Grady
That fitting is for the carb bowl vent. It should have it's own hose that goes from there up to a hole on the inside of the upper frame rail below the fuel tank. The one on the bottom is the bowl overflow fitting/hose. It should run down and have a one-way check valve in it.
Discussion Starter #10
OK thanks , that is in sight, no problem. Then where does the black plastic, right-angle fitting on the side of the carb connect?.....Lotsa' things not there when I picked this up
:hmmm:
Grady
That should be a vent line also. Do you see more than line going up?
Discussion Starter #12
No. As I got it, there was a line down off the bowl with a tee in the middle (connected to nothing) and with the valve at the bottom. The upper vent line (into the frame) was not connected nor the one on the side of the carb. All 3 are the same diameter.
Sorry to be such a PITA!
thanks, Grady
Discussion Starter #13
Kit on the way. Still running gas like a sieve. ya' know, I really don't understand $36-$52 for a needle and seat when a kit can be had for $16-$30?!?!?
:ponder::ponder:
1 - 13 of 13 Posts
