1 - 2 of 2 Posts
The plastic finger that moves (with the gear shifter) switch from Forward to Neutral and Reverse finally broke. This left me with no means to engage the AWD. I took the switch a part and pushed in a shim to keep the switch in the forward position.This seems to work fine for both Forward and Reverse 2WD and AWD no need to push the override button. Anyone have this issue and what is the purpose of the reverse override?
the reverse over ride is for safety reasons. so you dont go into full power in reverse. im guessing to cover polaris for law suits. from like kids driveing it and what not. you can just remove the switch and add a toggle switch on the headlight pod. so then you wont need the yellow override switch.
1 - 2 of 2 Posts
