I'm new here- Thanks for any help I have a 425 magnum that will go into reverse and low forward. It rinds when trying to put in high forward. Any guidance on adjustment ?
u can try adjusting the shifter linkage that goes from the shifter to the transmission.... u have to turn some bolts and it will extend the rod. But if you do it too much it will grind going into reverse. So just turn it like twice then crank wheeler and put in high and see what it does. real simple! :veryhappy:
put tranny in nuetral , adjust rod ends so they go into shifter and tranny perfectly straight, also check ends for wear, if they are sloppy,replace them
