1 - 2 of 2 Posts
I replace the carburetor and I think the lines are not correct is there a diagram I can look at there's two lines at the top of the carburetor with breast nipples where does those go to I see fuel in the line in the clear plastic something doesn't seem right
The two nipples on top of the carb are float bowl vents (they let air into the float bowl) - engine side of carb on RH side nipple is vacuum port for fuel pump - air box side nipple on LH side of carb is fuel inlet from the fuel pump - nipple on the bottom of the float bowl is overflow/drain nipple.
1 - 2 of 2 Posts
