1 - 2 of 2 Posts
Had this issue for some time. 4x4 goes in and for no reason goes out. Light corresponds to the 4x4 issue.
Before I noticed the battery was completely dead, the head lights and 4x4 would go out for some time then go on for awhile then back out, but it would still run fine. Also noticed the reverse ( engine governor) did not work when everything else wasn't working. I thought the battery was the issue so installed a new one and problem still exist.
Will the rectifier have something to do with this?
Volt meter the battery should be 13.4 ish. The rectifier could be surging or the stator.
Sent from my SPH-D710 using Tapatalk
1 - 2 of 2 Posts
