i would recommend getting the proper tool to remove and put back the clamp for the boot over the CV joint. you can do it with needle nose pliers, but it is way hard the first time you try to do it.
other then that, it is fairly straight forward. take your time, look at how everything is together before you take it out, and dont mash up the splines.
sorry dont have specs, i dont have a book
if the boots are already on then that makes it easier. just make sure to get plenty of grease on those boots before you ride it
