Whats up, I'm new to this site. My parents have a sportsman 335 that's been sitting for two years with the same gas in. :spank: I told them I'd do my best to get it running for them but I'm definitely going to need some help from you guys. I couldn't get it to turn over, go figure, so I drained the gas put fresh premium in it, opened up the carb a bit and got the float unstuck. I tried to get it to fire again and could only get a couple rotations with help from some carb cleaner. I also noticed it's leaking a bit out of the nipple on the bottom of the carb. If you got any tips or tricks I'd appreciate it.
Sounds like you need to clean and rebuild the carb.The gas leak is probably the needle and seat.
