I have a 99 sportsman 500, and am needing to replace the inner rear cv joint.
I was wondering what is the easiest way to remove it from the transmission, and what is the easiest way to but it back in. I am new at this and could realy use some help.
First welcome to the board!
The axle should pull straight out from the transmission. There is a c clip that holds it in place if you can see it try to spray some lube on it. If that does not work you can get a small pick through the splines and if you can see the c clip you can try pushing down on it while you try to remove the axle. This is an easy process if they are not rusted otherwise it just takes time.
