Just wondering why my ATV overheats and quits. It seems the fan isn't coming on very often. Any thoughts?
Pull the wires off the thermal fan switch at the top of the radiator. Jump them together to make sure the fan works like its supposed to. There should also be a circuit breaker in the line that may be bad. The radiator must also be completely full since on those older models the thermal switch is in the top. If coolant gets too low it won't turn the fan on.
