I was wondering if anyone has changed the A Arm Bushings on a 2007 500 Sportsman? I have the parts and think it should be fairly simple but just thought I would check with you all first. First time on this site looks pretty good and may be a good place to hang out.
Thanks,
ya. its easy. i havent changed them. but just jack the atv up a little bit to support it while you remove the bolts that hold the a-arm. remove the a-arm and pull the plastic bushing out. reinstall in revere. grease. then your done.
