1 - 1 of 1 Posts
according to the wiring schematics the acc fuse is fed off a red/wht wire which is fed off the main fuse. both are 20 amp fuses, with all of the efi system running off red/wht wires useing up some of the amperage of the main fuse, if i run 17 amps(i want to run 16.6 with lights and hand grips, 70w fog,100w hi, 30w grips, 200w/12v=16.6a) wont that put to much strain on the main fuse and cause it to blow or am i missing something? like acc being triggered by main when turned on?
1 - 1 of 1 Posts
