I noticed two wires hanging down toward right side of headlight pod? Are they accessory wires? I had dealer install heated grips but noticed under the hood it appears that both orange/white wires are being used....?
The orange and white wires under the pod are your ACC wires. Any other components possibly the winch???
Both orange/white ACC wires are being used by the heated grips?
Well both of the orange white wires under hood are being used...I am assuming for heated grips and the pre installed winch (19 Premium XP)
So what's the issue??
Well have the wireless winch remote to install and the orange wire is suppose to be hooked into one of the 2 Orange/White wires under hood but noticed they are already being used.....
Fabricate a splitter using one male and 2 female wire terminations and plug the winch in along with the one of the heated grips.
Yup you'll have to crimp two wires into one spade and connect it to the orange ACC wires. FYI you may have to oversize the spade to fit two wires under it.
