When I plug anything up to the accy plug and just idle its fine but If I give it gas it blows the fuse. Does that sound like a short or something else? Im not that great with wireing so any help would Help out alot!! Its a 2013 850xp
^ X2 sounds like voltage spiking causing fuse to blow. Put a volt meter on it and see what you gotWhat are you plugging in? Have you checked the voltage at the plug, could be a faulty voltage regulator. At idle the current out put is limited, but as engine speed increases the stator produces more current.
Gonna give that a try tomorrow also.can you try plugging a different accessory into the plug? that way it will eliminate the radio as a problem.....
