Hear is a missing part that didn't know how to explain.
The ADC doesn't only engage the the front wheels it also has some kind of brakes has well and that is the part that AMSOIL doesn't work with.
I remember when I first got my Sportsman xp 1000 you let off the gas in ADC it would pull the rear wheels off the ground.
If you can't see what the picture is showing I will write it out.
(Visually inspect the clutch plate area if plates are steel on steel or if the friction material is worn the assembly must be replaced.)
Pretty sure mine are steel on steel after the Amsoil because it squealing before I gave up.
I have more a problem now than in will not even engage the front wheels.
