I have the light bar mounted OK the problem is with the wiring harness. I need a place to mount the toggle switch the only feasible location is in the left side of the bike where there is a rubber stopper. The hole is a little to large for the switch to fit flush and tight I see my on option is to drill a 3/4 hole in the rubber stopper. Has anyone done this before is this location drillable?:dunno:
I mounted mine to the left of the speedo.
I used the hole under the stopper for my LEDs. The hole on my 570 is "D" shaped, (I think its where the choke is on carb models) I mounted a round weather pack switch sideways (turns on off side side versus up down) put a little epoxy on the back inside the pod, and used a conduit collar to keep tension on her. Has held up fine no issues. I thought I had some pics of the install but I guess I don't, apologies.
I took my high beam out and REPLACED it with a light bar :D
