Hi All,
I just purchased an 04 Polaris Sportsman 400 4x4. I noticed that the front tires are pointing toward the inside, they are not straight. What controls the adjustment of the camber/toe and how can i change it?
Thanks!
I think you better take a pic for us to show how "bad" it is.. or better yet some measurements
You dont want to mess with it. There NOT Going to Ever be straight. (Negative Camber is Factory) Also Toe In of 0.4-1.2" is what i see on most Quads (Factory)
This is not From a Polaris Quad. But most are the same.
Caster/Camber is not adjustable.
Camber and toe are different.
Your toe IS adjustable with the TRE adjustments.
Caster will be effected with the condition of your front springs... Not really changed, just made more obvious...
How does it ride?
Discussion Starter · #4 ·
my issue is definitely toe. I have some negative camber, but not much.
So the TOE adjusts at the tie rods?
Thanks!
