Agreed, especially on the cheap China carbs. I have yet to replace one on an ATV that worked properly. If it did work okay, it didn't last for long. I replaced one on an Arctic Cat ATV I used to own and it ran well right up to just after the warranty expired. So I pulled the float bowl and was astonished to find metal shavings in the bottom, and lots of it too. The only way I can see that happening is either someone deliberately did that, or they installed the float bowl on with the carb above their head. No way all that metal shavings could have remained in there if the float bowl was turned upside down, as one would expect, during assembly.
Have a neighbor down the road that purchased a China carb for his ATV. It cuts out and barely runs now.
Also, I have purchased and installed many cheap China carbs for small engine equipment that I have worked on for other people. One of which is a friend. I told him that I could get a new OEM carb for that piece of equipment but it would cost him ~ $100.00. I gave him the option of taking a $25.00 chance on a cheap China carb. He chose the latter. I installed the China carb and it ran fairly well at first but it only made it about an hour before it went belly up. I was there when he was running it when it died.
I do not recommend a cheap China carb for anything. Much better off buying an OEM carb, even though they are more expensive. Buy once, cry once.
Cheap China carburetors are so problematic (reads junk) that I will no longer purchase them or install them for anyone.
