could someone point me in the right direction i have a polaris trailboss 250 im working on need some help with
Discussion Starter · #4 ·
Ok it needs a new piston also gonna have the head honed .when i pulled the starter out to see why it was not working i opened to check the brushes thats when i found oil inside the staeter ..my next question would be ..cleaning out the bottom end do i need to add oil or will the oil pump {if working right} pump oil into the crank shaft bearing
Replace your starter, I got mine brand new from mfgsupply.com for $50. Yours looks to be $99. there should not be oil in the starter. This is probably just sludge fromwater getting into it. Rebuild the starter bendix, it is easy to do.
when you replace the piston, use assembly lube and that should do it. Once you are breaking the engine in it should oil the engine normally. Use the assembly lube from autozone in the black and white tube that has moly in it.
