where did you get that badboy, and does it have the fitting in the same place ie. direct fit replacement.if it is i want one especially if it has thoes cooling fins!
It's a bolt on except for the oil Intake fitting on the engine. The plastic tank uses a 1/2" ID line. The Aluminum tank uses a 3/8" ID line.
Using the smaller diameter hose and fitting will not be a restriction. The 1/2" fitting has the same ID as the 3/8" fitting. However. Both oil Intake and Return lines will have the same ID so they could be installed in the wrong position.
I'd rather keep the differing diameter hoses to prevent mixups. So I'm using a 14mm Banjo to 1/2" hose barb fitting.
14MM BANJO TO 1/2 BARB - STEEL
With the above Banjo fitting I can shorten the stock oil intake line and clamp it with Fuel Injection Clamps.
Reconditioning parts list;
Q, PART# - Description
1, 5830053 - Polaris GASKET,OIL RESERVOIR
1, 7052163 - Polaris FITTING,OIL RESERVOIR VENT,NYLON
4, 7555896 - Polaris CRUSH WASHER,COPPER, 14MM BANJO
1, 5850135 - Polaris CRUSH WASHER,PLASTIC, OIL DRAIN
1, 2530020 - Polaris FITTING SCREEN-OIL FILTER INTAKE,BANJO
2, 5410828 - Polaris GROMMET,MOUNTING
1, 5410889 - Polaris O-RING,DIPSTICK
1, 7052109 - Polaris TUBE,BANJO,RETURN (If you're not re-conditioning the original and using the stock 3/8" return hose with a Fuel Injection Clamp)
Stock Polaris 2001 & prior oil intake hose parts.
1, 3084842 - Polaris FITTING 3/8",OIL-INTAKE (Use with 7052133 Intake Tube) {Not needed if you use 14mm Banjo to 1/2" barb fitting on tank screen fitting}
1, 7052133 - Polaris TUBE,BANJO,INTAKE (Use with 3084842 fitting) {Not needed if you use 14mm Banjo to 1/2" barb fitting on tank screen fitting}
