1 - 10 of 10 Posts
So for my 800 Sportsman it says I need:
PS-4 Plus Performance Synthetic 2W-50 4-cycle oil (2 qts)
Active Descent Control Fluid
Premium ATV Angle Drive Fluid
Demand Drive LT Premium Fluid (front gear case 275ml)
Polaris Premium AGL Synthetic Gearcase Lubricant (transmission)(948ml)
Premium All Season Grease (for a grease gun)
Premium U-Joint Lube (for the drive line)
Dot-4 Brake fluid
So what you have for me??:)
Premium ATV Angel Drive Fluid
Dot-4 Brake fluid
I was waiting for you to ask all that 1200bruce so i wouldnt have to type all that thanks. and dito for me!!!! :smoker:
Great to have you on board. I only use Amsoil, but I get it off my best friend who is also a dealer
Everyone knows a dealer! I mean Amsoil dealer, yea that's it!:spankme:
Ok I don't know a Amsoil dealer, but then again I don't get out much!:call2:
Discussion Starter #6 (Edited)
AMSOIL Fluids for a Polaris Sportsman 800
Okay gents,
For an 800 Sportsman you will need:
PS-4 Plus Performance Synthetic 2W-50 4-cycle oil (2 qts) Is not an exact match but converts to AMSOIL Formula 4-Stroke PowerSports 0W-40 OR 20W-50 motorcycle oil. The 0W has a lower cold pour point
Active Descent Control Fluid converts to AMSOIL Synthetic Universal ATF
Premium ATV Angel Drive Fluid converts to AMSOIL Severe Gear 75W-90
Demand Drive LT Premium Fluid (front gear case 275ml) converts to AMSOIL Shock Therapy Light
Polaris Premium AGL Synthetic Gearcase Lubricant (transmission)(948ml) converts to AMSOIL series 2000 Chaincase Oil
Premium All Season Grease (for a grease gun) converts to AMSOIL Synthetic Heavy Duty Grease
Polaris Premium U-Joint Lube PN 2871515 converts to AMSOIL Synthetic Multi-Purpose Grease
Polaris Premium U-Joint Lube PN 2871551 converts AMSOIL Synthetic Water Resistant Grease
Dot-4 Brake fluid converts to AMSOIL Series 600 DOT 4 Racing Brake Fluid
If you would like specific information about a product or quote, just PM me.
Be sure to ask about my Polaris ATV Forums Special.
Take care,
Thanks for info. Willie!:rock:
Discussion Starter #8
Okay gents,
Take care,
My pleasure. One thing I forgot to add, is the Oil filter. Right now a lot of you are using the WIX 51356. AMSOIL offers the EAO13. The WIX offers a nominal filtering cability of around 21 microns, trapping 70-80% of all contaminants down to 21 microns. With the AMSOIL filter, you are getting nearly absolute filtering (98.7%) down to 15 microns. Far better than the WIX.
If I can be of further assistance just let me know.
Take care,
Can I use that in the Zirks(sp) on the F-150?
Thanks Bruce:fing02:
1 - 10 of 10 Posts
