1 - 1 of 1 Posts
ok i've been dealing with this since i've bought the quad, but recently it has been getting worse, it's a 2000 scrambler 500 H.O. 4x4
99% of the time when I first start the quad and turn the AWD on it works perfectly both front wheels lock in and spin. However sometimes when shifting from drive to reverse or reverse to drive the light will not come back on and I lose the 4 wheel drive. If I sit and play with it (shifting back and forth from reverse to drive, switching the AWD on and off or even shutting the quad off and back on) the AWD light will come back on and work perfectly for a little then it will happen again. I have eliminated the trans switch since I have neutral and reverse lights, have changed all fluids multiple times and have tired the YouTube "fix" of splicing the ground wires and connecting to solenoid. All that did was make the AWD light come, no front wheel spin.
Any help with this would be GREAT!!!
1 - 1 of 1 Posts
