1 - 1 of 1 Posts
I had a previous post related to this issue. My Inner front CV joint pulled apart when my A-Arm bolt worked its way out. The boot tore so I am replacing it. My issue is with figuring out how to get the the rest of the shaft out of the differential since the CV joint is separated. I know with it attached, you can jerk it out, but there is nothing to really pull on. Any tricks or suggestions?
1 - 1 of 1 Posts
