I know that the clutch kit is the solution for oversize tires/wheels and power loss, but what about just for even more power on stock wheels/tires? Is it worth the cash to install a kit if you have no plans to go any bigger? Has anybody done this? Also, does a clutch kit include a new belt?
same stock belt.
you can just get a different spring for the rear(driven) clutch.
About half the kits I sell go to customs with stock size tires. Most of the rest are only 1" bigger. Only about 10% have 2+" bigger tires. And absolutely there are changes you can make to get your stock machine to perform better for your specific use. Be easiest to call me and I can give you the details. 651-707-6706
Ryan
^^^^^^No doubt in my mind you are missing out on a lot of unseen power with factory clutching. Call Ryan and he will fix you right up with what you need. Trust me I just did a kit from QSC that Ryan helped me with and it is by far the best bang for your buck!!!!!!
