1 - 20 of 29 Posts
I was washing the 850 and I found this laying on the frame anyone care to guess what it is cause I have no clue.
Is it metal? When the universal joint broke loose on my Outty it left fragments such as that on the ground.
Yes its metal its very light weight.
It looks like aluminum. Are you missing any chunks off any of the aluminum casings from your machine?
seabee78
it looks cast aluminum..what ever area you found it I would start looking them areas over that are cast...it looks like something rubber may have been rubbing it by the black circular marks...
Something you picked up on the trail???
I found it under the drive shaft going into the front diff. Problem is I don't know what it looks like normally looks to have been a complete circle at one point in time. It is possible that I could had picked it up on the trail yesterday
I would look your atv over make sure no oil leaking anywhere. I am curious what this piece of aluminum is from?
Not a spot of oil anywhere
Damn! I know exactly what that is, I found one too!
It's from your winch. I busted two Polaris winches already.
unspool your cable and have a look
You da man! :rock_dj:
Nice job RangerBob!!
For the OP, this is classic bad news/good news. Bad news is that it's from your machine; good news is that it is not power train related.
Discussion Starter #13
Thank you for your help Rangerbob316. Does this mean my winch is shot now?
I did because mine was under warranty at the time. It still worked fine. I'm sure your seal is jeopardized now though.
Discussion Starter #15
This is why it busted that aluminium piece. Dang mud soaked sxs
Discussion Starter #16
Here is another pic. Sxs was stuck for 3 hrs
Pretty amazing that was winched out and up. Would have been a good spot for a snatch block.....or two.
Well that sucks!!! At least it is not part of the engine or trans casting. What make of winch it is??
Wow, that looks pretty rough!
Discussion Starter #20
We didnt have a snatch block but in the 1st pic i had a 700 grizzly attached to me. We were both pulling him. Rookie mistake i was pulling at an angle in 1st pic then switched to a straight on pull. We tried to pull him out backwards but with 3 wheelers but he wouldnt budge at all. So had to pull him out the hard way.
1 - 20 of 29 Posts
