I'm currently using Polaris oils all over my new quad but I've been thinking it gets to be quite expensive, around $80 every fluid change. I used to put shell rotella t 15w40 in my old 96 sportsman 500 since it started evaporating the oil due to an unknown over heating issue and it ran fine, so does anyone else use lubricants that aren't Polaris brand? It says in my new manual that you can use other engine oils but it may need to be changed more often, unfortunately it doesn't give the oil viscosity for the two gear cases anyone know what they take?
THERE is a section on lube on the forum..read thru it....lots use other oils....lots to learn there
Okay thanks! Didn't see it haha
