1 - 2 of 2 Posts
G'Day All;
Took the bike out for a rip tonight and as soon as I hit the snow I switched on the AWD and it killed the bike. When it was sitting there it did flick on and off continuously.
Some recent history. Had it out the May long weekend and was hitting some mud over the weekend then on the last day this also happened and got towed back to camp. Figured then it was water in somewhere. Got home and tackled it with the multim-eter and kinda figured the problem was in the switch with the lights, reverse override, kill switch, etc.. Got busy with work and life and hadn't touched it until Jan 3rd. Took it out for a few hours in the snow covered trails and no problems. Then took it out tonight and the problem is back.
I do believe it is either water (cause of the mud, then the snow) or just a loose wire. I printed out a couple pages from the service manual so I can tackle the problem tomorrow. Don't really know where the rectifier is.
My question is if anyone has experienced this as well, and what did you do to rectify it. Just am looking for some previous experience to shorten my project time.
Also, the bike runs just fine in 2x4.
Thanks in advance!!
Scott
Discussion Starter #2
Hey all;
I know there isn't much interest in this but figure I would post what I found just to give you guys something to read!
Once I tackled this problem it was a piece of cake and learned something for the future. It was only a frayed wire in the end, I will try and attach a photo.
The wire from the AWD switch to the front gearcase was all messsed up. On this model it is ran in the worst possible manner. Down the fronf along the frame in front of the Rad then cut back over the CV into the gearcase, positioned so every twig or stump can hit it. Next time I have the front all apart I will re run it to come more from the direction of the engine.
What I learnt was when I tried to order the little piece of wire from the connector to the gearcase about 8" Polaris said you can't you have to order a whole new gearcase. So through some butt connectors on and shrink wrapped it ip good and hope it doesn't frsy again because in time I will run out of wire.
Cheers
1 - 2 of 2 Posts
