Hi Guys
I was told I could use automatic transmission fluid in the front and rear diffs as well as the transmission, any thoughts on this.
thanks Duane
Are you talking about car/truck trans fluid?I hope you didnt put that in yet.If you did you may want to drain it out.You need a heavier lube like 75-90 weight gear lube.Use Amsoil synthetic if you can.
Na I havent put in in yet I just wanted to get a second opinion first. thanks for the reply.
